Octane Shorting Block
1) is fixed by running a cleaning agent (Seafoam is a common brand name) through the engine. This is not a fuel injector cleaner, this is a cylinder decarbonizer.
2) has a few sub-topics:
a) dirty MAF -- causes the computer to think less air is coming in so it feeds less fuel and the engine runs a little lean and pings. Fixed by cleaning the MAF filaments.
b) vacuum leak -- check vacuum and intake tubing and connections for leaks. One vaccum leak that shows up is through the lower intake manifold. Tightening the bolts will usually fix it (they come loose over time), but occasionally the gasket needs to be replaced.
Those issues seem to cure 90-95% of poeple's pinging issues on this engine. Try them and see if yours improves. If not, come back, I know a few less common fixes. If all that doesn't fix it, then you can go back to fiddling with the octane shorting block.
1) Ran Seafoam thru the intake.
2) Cleaned MAF Sensor.
3) Cleaned IAC Sensor and IAC valve
4) Cleaned Temp Sensor
5) Replaced plugs, wires, fuel filter and air filter.
6) Replaced upper intake manifold gasket. and tightened lower intake manifold bolts.
Not sure what more I can do. I'm thinking of installing a 180 degree thermostat and maybe running a set of Autolite APP764's which are a 1 step colder plug. I'd still like to be able to flip the switch I installed with the engine running for those times when it starts pinging too much, but like I said I'm not sure if it will hurt the computer. Right now I just pull over to the side of the road, turn the ignition off, flip the switch and then start the car, but sometimes finding a place to pull over is a pain. Any further thoughts/suggestions would be appreciated.
Any signs of other vaccum/intake leaks? I've heard of some people having problems with the air intake tube developing cracks.
Another fix I saw someone mention is a good fuel injector cleaning -- above and beyond running injector cleaner through the gas tank. If you go to the trouble of replacing the lower intake manifold gasket, part of getting to the gasket is to remove the fuel rail. Get some good cleaner and make sure the injectors are clean while you have them out.
An ECT that reads too hot causes to computer to run the engine lean, so make sure it's reading accurately.
I'm not sure about the long term effects of leaving switching away from octane shorting block. I don't think it would have any ill effects, but I'm not sure.
