Sponsored by: Real Truck
V10 Ping, octane, and chips
Old Dec 11, 2003 | 10:07 PM
Dwinn's Avatar
Dwinn
I have a stock V10 in a 2000 F250 4x4. I have notice that when I go up hills and put start putting a load on the engine, I get engine ping. Normally I use 87 octane. Is there something I need to check or do I need a different octane? Also, Would the new Superchip Microtuner help me alleviate this problem?
I have also noticed a lot of posts on here concerning the pros and cons of using higher octane. Some say it's great while others give caution. Is there any technical authority out there that can address this?
I'm thinking the new SuperChip 1715 microtuner with the three programs might be a good bet to help with the ping.
Old Dec 11, 2003 | 11:08 PM
99f350sd's Avatar
99f350sd
Your engine should never ping if its stock... A couple of things
EGR valve Is it working properly? Is it dirty?
Really bad gas.
Maybe have dealer reflash.....Microtuner will only make it worse, at least with 87 octane.
Bottom line: you shouldn't be pinging with 87 find out why first.
Old Dec 12, 2003 | 07:39 AM
NoMo's Avatar
NoMo
Check your owner's manual to be sure, but I remember either my '00 or '01 manual saying that a light ping under load is normal. It was somewhere in the section that talked about fuel octane. Still, try some different fuel stations- staying away from the "no name" brands.
reamer
15
Jun 2, 2016 07:40 AM
Eric K
Modular V10 (6.8l)
126
Apr 20, 2008 12:35 AM
Pinhead-227
Computer Chips & Tuners
Feb 5, 2008 10:15 AM
dansV10
Aug 24, 2005 02:26 PM
Dwinn
17
Jan 17, 2004 03:57 PM
