MPG advice
Old May 31, 2004 | 11:45 AM
e35094's Avatar
e35094
Question MPG advice
I'm a newby to this page, and I have been reading the forum for two days looking for good info and I am about as confused as I can be.
Here's what I have. 1994 E-350 extended. 4.9 inline six, I think I have a C-6, though there is conflicting info on this page. P-R-N-D-2-1. I have tuned this engine completely and am getting all clear codes. I am using sythetic oil. I don't know what gears I have but I will find out.
This is what I do, I am a courier and I run 300 miles a day hauling about 1/2 to 3/4 tons of library books. Mostly flat with a few hills, and the majority of the time 60-65 mph.
I am getting about 14 mpg every day. Which seems about normal from what I have read in the forums. So I am spending about $200. a week for fuel. Under these conditions any increase would amount to a quite a bit of money in a years time. The six seems to be straining most of the time on acceleration and up hill and is at pretty high rpms when cruising.
As best as I can tell, swapping engines would not help a lot and would not be as bullet proof as the 300 is but adding overdrive would seem to be helpful (possible AOD swap?). I don't know about the gears do I need to go a bigger number or smaller?
I know this is pretty sketchy but what advice does anyone have?
Old May 31, 2004 | 12:14 PM
acerockola77's Avatar
acerockola77
I'd be happy with 14mpg if I was you. That sounds rough, but you're probably never going to get better than 16mpg even with a OD tranny.
Old May 31, 2004 | 12:19 PM
couleeman's Avatar
couleeman
I will only get 14-15 in my half ton if it is all highway driving. The price it would cost you to switch over to AOD tranny, is probably not worth it.
Just a little note, my truck gets the best gas mileage when I try to run it at 1800-2000 rpm's, however, it is guttless at that. Hopefully this will help.
Old Jun 2, 2004 | 05:12 PM
sglaine's Avatar
sglaine
Posting Legend
Replace the air filter more often and see what happens you will bw amazed.
Old Jun 2, 2004 | 06:06 PM
the_hetz's Avatar
the_hetz
Old Jun 3, 2004 | 07:35 PM
Saurian's Avatar
Saurian
My truck the other day got a recorded 17.8 mpg with my M5OD tranny.
My recommendation to you? Drive 55 mph instead of 65. Your engine wont' have trouble at that speed, and plus - for every 5 miles over 55 you go you generally lose one mile per gallon of gas. I understand you're traveling 300 miles a day...but if you want better economy.
The 300's torque starts to really come on about 1750 and continues through 3000 - peak is like 2200 rpm's. HP peak is at 3400 rpm's.
Anybody know the redline on 300's?
Old Jun 4, 2004 | 11:18 AM
mavinwy's Avatar
mavinwy
Slowing down will help, but I have been playing with my truck to see what I can get for MPG as well for highway.
I would change out the fan to an electric. Anything over 30 MPH and you don't really need to run the fan as airspeed pushes enough air through the radiator. I would of course put it in with a thermostat controlled electric for safety anyway. (you do have to drive slower sometimes )
But on the highway, you are dragging the stock fan (even with a fan clutch) when it is not needed.
You can also change your rear end lube to synthetic. I made both of these changes (Along with a more open exhaust when it needed replaced anyway) and got 3-4 additional mpg on the highway. That would save you about $30 per week. The fan kits are around $100-120 so you would pay for it in about a month.....
Just a thought.
Jim
Old Jun 6, 2004 | 01:43 PM
e35094's Avatar
e35094
Thumbs up
Thanks for all the input, it gives me much to consider. Gas is going down a little so I think I will hold off a while on the major changes but I will do the simple things.
whalerron
Apr 19, 2020 03:45 AM
acnels
Mar 14, 2008 04:59 PM
bucks77ford
27
Jan 19, 2007 12:56 PM
e35094
Jun 14, 2004 04:57 PM
e35094
Jun 6, 2004 07:36 PM
