exhaust hangers
Old May 30, 2004 | 06:55 PM
joners's Avatar
joners
exhaust hangers
How many exhaust hangers should be used? Dual exhaust, dumping before the rear tires.
Old May 30, 2004 | 07:16 PM
jniolon's Avatar
jniolon
old and in the way
hang it all
Steve,
I just had mine done... it's welded at the header outlet... one before the muffler (behind the cab) then there will be another behind the muffler holding the turnout...
After the turn leaving the header it's a straight shot (with a slight smush down at the trans cross member to gain some height) all the way back to the muffler...
hope it helps
John
Old May 30, 2004 | 11:12 PM
joners's Avatar
joners
Can you grab some pics of where exactly the hangers attached too? And what type of hanger?
Old May 31, 2004 | 10:53 PM
53Merc's Avatar
53Merc
Wink Trick Question?
Is this like the How many Chevy owners does it take to screw in a light bulb???? or How many Angels can dance on the head of a pin??
I don't know the answer if you're running a stock set up, but if you're running a modern engine and duals Mr. Niolon's answer is as good as any
It's really up to you, you want it to hang firmly without putting undo stress on the unions... a kind of "marital therapy"
GW
Old Jun 1, 2004 | 04:05 PM
Jag Red 54's Avatar
Jag Red 54
My duals go out the back, so the rear cross member is very handy. The hangers are the wrap-around type and are tack welded in place. Just look for a convenient cross brace or trany support. The hangers start off long and you trim them to the desired length. Good luck, John
