Rear Diff. Fluid
Old Apr 16, 2008 | 07:17 PM
betontheturtle's Avatar
betontheturtle
did rp in mine and changed out the rear diff cover to the new ford cast alum finned cover paid $28.00 from the dealer. it looks great and should keep the diff cooler.
Old Apr 16, 2008 | 11:32 PM
jjbirish's Avatar
jjbirish
2000 limited owners manual calls for for dyno in the rear housing and syn. in the front...
while brand loyality isn't bad, any lube that meets mfg spec should be ok to use...
some time ago i saw test results that had supra-tech syn motor oil rated as a best buy... you can be sure that same oil comes in cans with other lables on them... price has no bearing what so ever on it...
i use mobil one products and like them... i like them because i have never had a oil related problem while using them and am comfortable with them, price isn't a issue
Old Apr 18, 2008 | 10:48 AM
AltaEx's Avatar
AltaEx
Anyone else make a change to the larger capacity covers?
I'm wondering because years ago when Volvo was owned by Volvo, my brother's V6 GLE took something like 7 or 8 quarts/litres of oil! For some reason that manufacturer thought it was worthwhile. Maybe it was because they advertised back then that the average owner kept their Volvo for 17-years!!!
Old Apr 19, 2008 | 07:34 AM
vettdvr's Avatar
vettdvr
Rear Diff Gear oil 8 Pint F1TZ-19580-B WSL-M2C192-A 75W140 HP Synthetic Axle Lube Lubermatic OEM Synthetic 70w 140 States on lable meeting spec.
Rear Diff Limit Slip additive 35 ft lbs 1/2 Pint 16 oz C8AZ-19B546-A EST-M2C118-A TransX Limit Slip Tube states on label meets spec
I changed oil at 130,000 miles the oil was clean, gears showed no detectable wear. I also made sure the oil met the Ford spec.
the_auto_tech
2009 - 2014 F150
28
Jun 13, 2016 01:50 PM
kd0axs
Nov 9, 2012 10:53 PM
ttttmaxx
20
Oct 7, 2010 07:18 PM
trike1946
Nov 3, 2006 05:21 AM
ford390gashog
Oil & Lubrication
Aug 9, 2005 02:57 PM
