Sponsored by: Real Truck
Rear differential
Old May 29, 2004 | 11:42 PM
Black88GT's Avatar
Black88GT
Rear differential
It looks like fluid is leaking out of it, right where the diveshaft goes in. Is this a common problem?
Old May 30, 2004 | 01:32 AM
aldridgec's Avatar
aldridgec
Not neccesarily, but it does fail. The pinion seal is leaking most likely
Old May 30, 2004 | 01:52 PM
brwolfjr's Avatar
brwolfjr
my truck has had this problem 6 times now. and I just reached 32k
Old May 30, 2004 | 01:58 PM
jadel's Avatar
jadel
You must have the wrong seal or it was installed the wrong way.
Old May 30, 2004 | 05:46 PM
CanadianFordtech's Avatar
CanadianFordtech
Make sure that the diff. vent is not plugged. Have seen it before when seals keep on leaking. Diff builds pressure from heat and oil gets forced out of seals.
