No start problem
Old May 29, 2004 | 07:31 PM
hpatino's Avatar
hpatino
Unhappy No start problem
Hi, I'm a 1st time user & I gotta problem...go figure. I found a fuel leak on the valley under the fuel filter of my '96 F350. I figured it was an old hose or the "O" rings on the water separator. So, I trotted down to my local Ford dealer to buy the hoses & scrounged for the "O" rings. Long story short, After I assembled everything back together the truck wont start. It cranks fine, The tach rises just a bit during the crank and all fuses appear Ok....where do I go from here? After viewing a bunch of the PSD threads seveal have talked about the CMP sensor. Should I start with that or call for the tow truck?...Send Help!
Old May 29, 2004 | 07:44 PM
Fire Rooster's Avatar
Fire Rooster
did you fill the fuel bowel in the water separator with fuel or DFA after changing over the hoses etc. ?
Fire Rooster
Old May 29, 2004 | 11:09 PM
hpatino's Avatar
hpatino
I did & checked it after it wouldn't start the first time...still full
