Sputtering
Old May 29, 2004 | 07:30 PM
n2music's Avatar
n2music
Sputtering
Truck was running fine for a long time, then all of a sudden it starts sputtering while accelerating from a stop. Starts OK, idles OK, revs good while in park. Put in gear and pull off and the sputter begins. Get up to speed and goes good but can tell it is not as strong as once was. 390 Edlelbrock Streetmaster Holley 670cfm StreetAvenger, electronic ignition (Duraspark) new distributor, adjusted on carb, gap set to .040. 300 miles on motor. Any help or ideas greatly appreciated. Thanks.
Old May 29, 2004 | 11:01 PM
Torque1st's Avatar
Torque1st
Posting Legend
Test your ignition module at a parts store. Also check for a bad pickup coil and wires in that new distributor.
