battery tray replacement options
Anyway, the tray on my beater was in somewhat decent shape, but it was failing fast. So, I used it as a template. I'm mostly done, but I still have to work out some finishing touches. It is made out of 3/16" plate, so it'll probably last about 20 more years than the factory one. I'll post some pics when I am done.
So, that leaves my beater without a place to mount the battery, and a '94 battery tray, and some left over 3/16" plate. hmmm..
this is what I came up with, I still need to get a '94+ hold down clamp, but I should be able to find one in the yard pretty cheap.. I actually like how easy this one was to build.. If you need to build one, go find a 94+ in the junkyard, and do this.. pretty simple and only took a couple hours, not to mention save you about $50 bux, unless you live in a 'sunshine' state where none of your trucks rust...
http://mav.wastegate.net/images/battery 1.jpg
http://mav.wastegate.net/images/battery 2.jpg
http://mav.wastegate.net/images/battery 3.jpg
http://mav.wastegate.net/images/battery 4.jpg
http://mav.wastegate.net/images/battery 5.jpg
http://mav.wastegate.net/images/battery 6.jpg
http://mav.wastegate.net/images/battery 7.jpg
http://mav.wastegate.net/images/battery 8.jpg
http://mav.wastegate.net/images/battery 9.jpg
http://mav.wastegate.net/images/battery 10.jpg
question, comments, anything, lemme know...
p.s.: didn't know how gay the OHSA safety yellow would like until I sprayed it..
http://www.bigblocksix.com/f100swb/F...atterytray.jpg
http://www.bigblocksix.com/f100swb/F...tterytray2.jpg
Bolted right in, no problems whatsoever. But, the late model plastic holdown thing sucks in a high vibration enviroment, hence the 80-86 holdown
mine didn't. I'm guess they changed them in 94, since mine had F4TZ stamped on it..
I just welded an extra flange on it so I could bolt it up to the charcoal bracket thing...
how does the plastic flange fail? I was thinking about making one out of plate.. but that would probably destroy the battery..
