351w problem
Old May 29, 2004 | 02:48 PM
Lost's Avatar
Lost
351w problem
I'm a bit tapped on money so i'm coming here to hopefully find a faster answer to what my problem might be.
Here's the problem:
For about the last 2 or 3 weeks I have had a problem with my '83 bronco when i would first drive it. It would idle perfectly fine, but once i hit the gas it sputters and would barely go anywhere. It was starting to get really bad over the last week and would even stall at times also.
I changed the spark plugs hoping it was a problem with them, i put new ones in correctly gapped and it ran fine for about the first 5 mins, and then tried dying on me when i stopped. I found out the problem there was a loose spark plug wire.
So then i went to drive it again after rechecking the gap and wire connections, and it would sputter when i would accelerate, and it does it regardless of having driven the truck already or not.
I replaced the distributor cap and rotor as they were corroded but it's not a problem there either.
I'm thinking my next step should be to replace the wires but they only have about 10-20k miles on them and seem fine?
Any help would be appreciated
Old May 29, 2004 | 03:50 PM
jwtaylor's Avatar
jwtaylor
Another easy thing to change, just to be sure its not something simple, would be the fuel filter.
Old May 31, 2004 | 01:05 AM
mjl351w's Avatar
mjl351w
how many miles are on it ? almost sounds like it is time for a timing chain. If i was you i would pop the dist. cap and check the timing chain slop
Old Jun 19, 2004 | 08:01 AM
dlberry1969's Avatar
dlberry1969
I was originally looking for a vacuum line diagram/schamatic for a 84' f-150, 351w 4brl.. But coming across this posting, it sounds like i have the same problem as your having. The truck will start and idle great. Sounds like a engine should. But after about 5 minute of driving the truck, it decides to die on me. I have tried the same things as you have, plus some. I believe it has to do with the vacuum lines, or the fuel lines. It could also(maybe) be the whole fuel-air compression system, which is the carborator. Any thing anyone could tell me to help out would be great. My only mode of transportation is down till i find out what it is exactly.
Old Jun 20, 2004 | 06:52 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
I know to some people this may seem wrong , but in the past ive have had
the same problem and it was a slowly failing fuel pump. These 351ws seem
to eat fuel pumps after buying bad one after bad one at the parts stores
i bought a hp holley. And problem gone!
Old Jun 20, 2004 | 08:12 AM
71swissaqua's Avatar
71swissaqua
I agree with JWatylor. Check the simple stuff first. Check your fuel filter. also check your timing is correct and check that your accelerator pump is working.
Clint
Old Jun 21, 2004 | 11:29 AM
loudfords's Avatar
loudfords
Also check the ignition coil.
Old Jul 23, 2004 | 09:34 AM
fulthrodle's Avatar
fulthrodle
I had a very similar problem. turned out to be a stuck disk in my CAT. After I kicked it a few times it un cloged. Obviously had to replace the cat
Old Jul 23, 2004 | 02:02 PM
gonetruckin's Avatar
gonetruckin
yeah the best thing to do would be to check the simple stuff and if you have points dont forget you points and condenser.
Old Jul 23, 2004 | 04:22 PM
Kemicalburns's Avatar
Kemicalburns
carb might need to be rebuilt or the vacum lines are not plugged in correctly.
