General Automotive Discussion
ECT sensor
Old May 29, 2004 | 06:52 AM
jkorreck's Avatar
jkorreck
ECT sensor
Ok, I just read a thread in the aerostar forum about an engine stalling out and running really rough due to a bad engine coolant temperature sensor. I've seen this before in other cars as well, my question to anyone is can someone explain why and how a coolant temp sensor effects how the engine runs?
Old May 29, 2004 | 09:25 AM
5_labsownus's Avatar
5_labsownus
In the EFI vehicles the Coolant sensor is your "Choke". The computer uses the temp. to gauge how to mix air/fuel and control the idle. It uses the O2 sensor to keep these in proper ballance based on the temp.
Old May 30, 2004 | 05:56 PM
jkorreck's Avatar
jkorreck
Thanks, makes perfect sense now.
Old May 31, 2004 | 05:01 PM
campinrig's Avatar
campinrig
This is why some guys will put a lower temp t-stat in there vehcal. Ect sees this as a colder condition, thus increasing the fuel pulse width(injector on time), More fuel more power....Not a lot though.
Old Mar 18, 2005 | 10:10 PM
jmolter's Avatar
jmolter
cool i think you have solved my problem i hope. describes my symptoms. just 1 question were the hell is the ECT??
Old Mar 18, 2005 | 10:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
It differs, usually near the thermostat housing or the outlet to the top radiator hose. Your repair manual should show the location or you can check with your particular engine/model forum if applicable.
Old Mar 19, 2005 | 03:47 AM
jmolter's Avatar
jmolter
hey thanks i found it
OldGrayFord
Feb 10, 2019 04:38 PM
grena
44
Jan 9, 2017 09:53 PM
midsouth
Nov 5, 2012 08:23 AM
Aggie05
1983 - 2012 Ranger & B-Series
May 23, 2008 10:42 PM
downunder1
May 25, 2001 04:53 PM
