Please help 302 carb issues
Old May 29, 2004 | 12:07 AM
packrat56's Avatar
packrat56
I have a 74' 302 in a 56, I put a rebuilt Motorcraft 2bbl from a company in FL on, I sent the "core" back before tuning (mistake).
Now I have a bad stumble/miss at constant speed. Idle is OK, not perfect, but OK. Accelleration, as long as the pedal is moving down, is good, but at a steady speed it is bad, runs rough. Feels like it is starving for fuel? Is this a main jet issue? What else could it be? I am lost, please help!
Old May 29, 2004 | 10:40 PM
LxMan1's Avatar
LxMan1
It sounds like the jets are too small, unless the float is too low and causing it to starve for fuel under a load.
Old May 30, 2004 | 12:48 AM
packrat56's Avatar
packrat56
Im having a difficult time finding Motorcraft main jets, in the "old days" we used to drill out jets. I have one spare pair of jets, they are #54s just like what was in this unit (in a 302 with a rebuilt , new to me, carb) I drilled the #54s out with #52 bit, it seems to be somewhat better. First of all, can anyone tell me what # jets should be in a 302, 2bbl, ???I was told has mild cam (not sure if its true).
Second, anyone have a conversion chart, or just a good handle on what drill size = what jet size? if a #54 jet is the same as a #54 bit, (and it is) then when I drilled it with a #52 drill bit which is bigger, did I make it a #52? or a #56? ....is a #52 jet smaller than a #54? I am thinking about drilling one more size to a #50 bit, is this crazy too big? or is it reasonable that it may need this much fuel, it still seems starved, float level is good, vacuum is good, and drilling to a #52 did help a but... HELP!!
Old May 30, 2004 | 04:05 PM
LxMan1's Avatar
LxMan1
There is no set jet for any engine, I would just go a little bigger until it runs good.
It's all a trial and error kind of thing.
eileen130202
Jul 27, 2013 02:36 PM
jimmyb08SD
Florida Chapter
Feb 6, 2013 10:04 AM
jimmyb08SD
Florida Chapter
Dec 20, 2012 06:43 AM
xlt4me
Oil & Lubrication
Sep 11, 2004 12:46 PM
