Tune up?
Old May 28, 2004 | 11:26 PM
Black88GT's Avatar
Black88GT
Tune up?
I have a minor miss (like a bad wire or plug). What can I do to try to fix this, or is this normal for a diesel? The truck is a 99 F 350 7.3 Thanks
Old May 28, 2004 | 11:53 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
A minor miss at what RPM?
Old May 28, 2004 | 11:54 PM
99PSDCREW's Avatar
99PSDCREW
Sounds like maybe another Camshaft Position Sensor? Ordering mine after the weekend from International for $85.90. Look up the searches on CPS and see if it relates to the problem you have. I also have the '99 PSD. (sig)
Any other ideas anyone?
Old May 29, 2004 | 03:53 AM
Black88GT's Avatar
Black88GT
Just at Idle, so Around 700 or so.
The previous owner said he had the CPS replaced already. He said it died out on the freeway Could I need another? The truck has 57000.
Old May 29, 2004 | 04:06 AM
Quadzilla's Avatar
Quadzilla
It's possible that you need anothe cps, but a more likely cause would be a bad connection at one of your wiring harnesses at the valve cover. It might be as easy as checking the connections on the outside of the valve cover, where the wires connect to the valve cover gasket. It could also be one of the connections inside the valve cover, where the internal wiring harnesses connect to the injectors and glow plugs.
Old May 30, 2004 | 01:52 AM
cookie88's Avatar
cookie88
FTE Emeritus
Might be as simple as needing the oil changed. Don't laugh, my truck gets all sorts of funny quirks when the oil gets old....including an occasional minor miss at idle.
Old May 31, 2004 | 06:59 AM
Black88GT's Avatar
Black88GT
Thanks for tht info guys I'll check that today.
BTW, How often should one change the oil one these? Its the same as a regular car right, just more oil?
Old May 31, 2004 | 07:03 AM
johnsdiesel's Avatar
johnsdiesel
Regular service is 5K miles and severe service is 3K. Yep, same as a car but a LOT more oil.
Old May 31, 2004 | 11:11 AM
CAT_man_963's Avatar
CAT_man_963
Also check out the fuel filter - wouldn't hurt to change that too if you don't know when it was changed last?? I'd say my truck always runs a tiny bit smoother with fresh oil in it too.
