Rear Differential Fluid
Old May 28, 2004 | 07:08 PM
vindawg82's Avatar
vindawg82
I've noticed a whining noise in the rear end of my 94 F150 4x4 and I'm pretty sure it's the differential. One suggestion was to check the fluid level. Any tips on how you would go about doing this?
Old May 28, 2004 | 07:37 PM
Jimbeaux's Avatar
Jimbeaux
There should be a filler plug with a 3/8 square female end on the frond driver side if memory serves, It should be filled to the point that you can touch the fluid with your little finger just at the edge. If not, get a 10-15 dollar manual at whatever auto store is in your area service it by the instructions. If you are cheap (Like me) go to the public library and take noes from the manual there.
Old May 28, 2004 | 08:07 PM
AJ Goss's Avatar
AJ Goss
If it does turn out to be low, fill it with either 75w-90 or 80w-90 gear oil. As stated, the level should be up to the plug.
