Warm Up ???
Old May 28, 2004 | 06:59 PM
Super Duty Fan's Avatar
Super Duty Fan
Smile Warm Up ???
With the new 6.0 l do you need to warm them before givin' her full throttle ? I am having an arguement with a co-worker about this, I say you should let it warm up for about 10 or 15 min, he says we are in the 2000's not the 1960's , with the technology today you don't need to warm up your truck. I have 2004 6.0 L king ranch he has a 2003 centenial 6.0 L. what does everyone else think????
Thanks for all the help and proving I'm right
SDF
Old May 28, 2004 | 07:20 PM
jasfaa's Avatar
jasfaa
I usually let mine warm up for about 5 minutes. The temp gauge has usually moved by then and that is my indication that everything should be good.
Old May 28, 2004 | 07:43 PM
johnsdiesel's Avatar
johnsdiesel
It's a good idea to let it idle for 10-15 seconds in warm weather and maybe a little longer in cold weather, but that's all that is needed before you start driving. You should avoid high RPM until the engine fully warms up though. A diesel will not fully warm up anyway until you start driving it. 10-15 minutes does seem a bit excessive for warm up.
Old May 28, 2004 | 08:03 PM
bighoss550's Avatar
bighoss550
as long as it takes to eat my breakfast it should b up on the temp gauge in 5 or so. thats enough i think. if i get in and go w/o the warm up, i get alot of smoke and rattles
Old May 28, 2004 | 08:20 PM
fyrhog's Avatar
fyrhog
I would get some heat into the motor for thermal expantion.As the motor warms bearing clearances increase for better lubrication,and oil flow.Oil flows better when heated,also its my guess that you would get a better burn of fuel in the cylinders.....just my 2 cents.
Ron
Old May 28, 2004 | 09:50 PM
DucatiSSsp's Avatar
DucatiSSsp
My method of warmup is:
Start truck, wait about a minute, slowly drive through the hood, hit the main roads keeping the tach under 2k. By the time I hit the onramp, about 3-4 miles she in the normal op temp, then I will give her more go-go juice!
Anything over a 5 minute warmup is wasting fuel IMO . Just warmup your motor fully before mashing the pedal.
Cheers,
Bryce
Old May 28, 2004 | 11:33 PM
Tadashi's Avatar
Tadashi
I do not think you have to warm it up but it will increase fuel efficiency and lubrication. I generally warm it up until the needle hits the bottom of the temp line. Then I drive easy/slow (no hard accelerations etc) until it gets to operating temps. My truck also seems to quiet down when she is warmed up.
PowerbyFord
General Diesel Discussion
Aug 26, 2021 06:39 PM
webstrang
Feb 9, 2015 01:57 PM
texas4x4
Sep 26, 2012 07:17 AM
colden
Jun 25, 2009 06:03 PM
Stratoscom
May 1, 2008 04:42 PM
