The normal re-flashing port is under the dash on the drivers side……we all know that much.
Does anyone know if there is any other, area that FORD can plug into and test/flash/ screw up the PCM…from?
can only acess pcm from wds w/ an obdII port never seen one w/ two. that would b some crazy wiring
