alt. bracket?
Old May 28, 2004 | 03:59 PM
boond0cksaint's Avatar
boond0cksaint
alt. bracket?
ok, on my 88 150, 2 of my bolts sheared off in the head. i got one re-threaded but cant get the other. my question is, will 2 bolts(1 at the 10:00 position and the other at the 7:00 position)plus the smog pump bracket bolt(underneath) hold my alt so i can drive it 30 miles to my shop where i work?i really need to get this truck out of the woods and back to the city. any info would be greatly appreciated. thanks
Old May 28, 2004 | 04:15 PM
DPS3749's Avatar
DPS3749
It should be OK. 3 bolts holding out of 4 should be fine. You could probably go a lot farther than the 30 miles. I'd go for it.
Old May 28, 2004 | 05:21 PM
boond0cksaint
ok, i was only able to bolt the lower and upper bolt, but seems secure. i just wont hot dog it on the way in tomorrow.
also need a belt routing diagram with smog pump elimination please, from anyone. h*ll ill even take some scribbles drawn in paint. thanks for your reply
