Sponsored by: Auxito
how do i test COP?
Old May 28, 2004 | 11:48 AM
myke's Avatar
myke
how do i test COP?
got a '97 with a 5.4. a while back she started missing going up hills, then would smooth out on level ground. turned out to be a bad COP. well, it's doing it again. i'm not getting a check engine light, so i don't know which one is causing the problem. is there a way to bench test these things?
Old May 28, 2004 | 02:21 PM
ranger88a's Avatar
ranger88a
Not that I'm aware of. The tool makers do make a nifty little tool to check them while running. You hold it in top of the coil and it will light up if the coil works. Only problem is you have to be able to get it to do it standing still. I use a tool from ford to diagnose them.
Old May 29, 2004 | 12:41 AM
LxMan1's Avatar
LxMan1
Have you scanned it to see if it has a stored code even though the light isn't on?
Old May 29, 2004 | 09:47 AM
myke's Avatar
myke
had it scanned at autozone. no codes.
Old May 29, 2004 | 10:19 AM
Racerguy's Avatar
Racerguy
It will cost a few bucks but your dealer can do a cylinder power balance test with their WDS scan tool. I assume that is what ranger88a is talking about. A miss usually shows up easily.
Old May 29, 2004 | 08:15 PM
ofcbob's Avatar
ofcbob
I'm not around my Chilton's right now but it has a method of testing. You would have to test them all until you find the right one but if you disconnect the wires and test the resistance across the two leads a functional COP should have a certain resistance. (4-10 ohms if I remember right) Also, the only COP I had fail physically changed color to a brown almost brittle look so you might, possibly be able to see a difference with a good flashlight.
Old May 30, 2004 | 05:42 PM
CanadianFordtech's Avatar
CanadianFordtech
Did you check for carbon tracking on plugs when you replaced the COP?
Old May 30, 2004 | 10:02 PM
myke's Avatar
myke
my FORMER mechanic replaced the COP last time, so i didn't see the plug. w-a-y too long a story to explain why he's my former mechanic. i keep reading here that it's not as hard as it looks to get them out, so i thought i'd give it a shot. just don't know what to do with em once i get em out.
Old May 31, 2004 | 05:42 PM
CanadianFordtech
The COP is held down with a bolt, 7mm socket. You want to look inside of the boot to see if there is a line. Looks like a pencil line. Also check for cracks or holes in boot, damaged connection(on harness and COP). Hope this helps.
Shambelous
Sep 26, 2011 03:54 PM
rat49f6
17
May 31, 2009 02:09 AM
jdhudall
1997 - 2003 F150
15
Mar 21, 2009 07:27 AM
Monsta
Modular V10 (6.8l)
24
Feb 4, 2006 02:04 AM
