Sponsored by: Real Truck
Air Bags
Old May 28, 2004 | 11:23 AM
JamesF250's Avatar
JamesF250
Air Bags
Can someone explain how air bags work?
Do they provide an adjustable ride height?
Old May 28, 2004 | 11:31 AM
wlihntr's Avatar
wlihntr
they mount between the spring pack(on top) and the frame, between the two mounts there is a rubber blader that you fill with air. they are designed to increase load capicity (level the truck with a heavy load) if you pump them up with no load it will raise the truck a few inches, but it will ride like it has no suspension at all. i have the firestone super duty's of the back of my truck. my slide in camper is about 2500# and i but 80 psi in each and it sits level
Old May 28, 2004 | 11:39 AM
JamesF250's Avatar
JamesF250
wlihntr -
So, this would NOT be a solution if I was interested in putting a lift on my truck but still being able to lower it to get it into the garage (wife's requirement)?
Thanks.
Old May 28, 2004 | 12:17 PM
wlihntr's Avatar
wlihntr
no, not the type of air bag i am talking about. there are air adjustable lift suspension systems out there. from the little i have seen about them you have to replace the entire suspension(shocks, springs..etc) with the air suspension kit. plus i have heard they are very very expensive...like thousands of dollars. maybe someone that knows a little more will come along. i have only seen those type of suspensions on show trucks...hope that helps
Old May 28, 2004 | 02:23 PM
subliminaldanger's Avatar
subliminaldanger
best bet to find those answers is to go to a site with a bunch of weed draggers since thats how they lift those trucks up to go over speed bumps. Or email a shout to the guys over at http://www.keldermanmfg.com - they make airbag lifts for superduties.
Old May 28, 2004 | 07:51 PM
Outpost22's Avatar
Outpost22
Maybe he means the Kelderman air ride system?
http://www.keldermanmfg.com/airride.htm
