Sponsored by: Auxito
Yes True Duals :)
Old May 27, 2004 | 07:54 PM
solidpwder's Avatar
solidpwder
Thumbs up Yes True Duals :)
About 2 weeks ago I got True dual on my truck (5.4L) with no mufflers, straight pipes. Its sound greeaat. and all it cost me was $200 at a local shop. I think its alot better then spending $500 on a borla system which doesn't even compare to the sound of 2 straight pipe. I don't know if I gained any mpg, becuase I'm always on the gas. Gained some hp but lost alot of torque. I used to be able to squeal the tire by just flooring it on a
dead stop, but now it just takes off with a load rummble. The best thing about it is when I start it up in the morning and the engine jumps up to 1300 rpm right away.
Old May 27, 2004 | 08:10 PM
LxMan1's Avatar
LxMan1
I'm sure your neighbors love that in the morning
Old May 27, 2004 | 08:18 PM
solidpwder's Avatar
solidpwder
Well the house in the way of are neighnors but the driveway is right next to the police department!!!!!!!!. but they won't do nothing to me because where I park my truck by the road. The police cars hide behind my truck to catch speeders.
Old May 28, 2004 | 05:44 PM
triton_2002's Avatar
triton_2002
You can't compare regular muffler shop tubing to a Borla system. Borla is expensive, but you have to consider the quality (all stainless steel, mandrel bends). I bet your pipes will be rusty in a few months, and that no muffler rumble will probably get annoying after a while. But thats just my opinion, whatever floats your boat
Old May 28, 2004 | 05:58 PM
Cruiseomatic's Avatar
Cruiseomatic
Arrow
How do you get a loud exhaust and keep your torque and hp up or higher?
Old May 28, 2004 | 07:51 PM
solidpwder's Avatar
solidpwder
well triton I never thought of that, I bet your right.
Old May 28, 2004 | 07:53 PM
openclasspro's Avatar
openclasspro
loud
l longtube headers- x pipe- spintech mufflers- 2 1/4" tubing- wicked sounding!
Old May 28, 2004 | 07:55 PM
Ultramagdan's Avatar
Ultramagdan
From a well designed system. I would add that stealth is better than a loud system that is torqueless, but as was mentioned "To each their own."
Old May 28, 2004 | 08:18 PM
froste's Avatar
froste
how do u lose torque, removing your muffler ??
Old May 28, 2004 | 09:42 PM
Ultramagdan
The system needs a certain amount of back pressure to achieve the right balance. Removing the muffler would remove some of the back pressure resulting in more rpm's (it's breathing free) but losing torque.
Bikes encouter this all the time when they remove the stock exhaust and install a free flowing system. They usually need to be rejetted and most of the horsepower is then made at the top of the rpm scale instead of in middle where most can use it.
Old May 28, 2004 | 10:32 PM
froste's Avatar
froste
I always thought that was what the cats were for. I didn't think the muffler had anything to do with the torgue or anything other than quieting the engine down.
Old May 28, 2004 | 10:37 PM
solidpwder's Avatar
solidpwder
I ask the shop that put my exhaust system on if he could put a x-pipe on and he said it would be to hard to. think I could get by with a H-pipe (I would have to cut holes into the straight pipe and weld one in myself). Would that give me some of my torque back. I just drilled 4 holes (2 in each pipe) in the staight pipe to allow the water to drip out. Im glad I did that after I did that I let the truck idel for 5 min and there was alot of water on the floor. even after turning the truck off it was dripping for about 10 min.
Old May 29, 2004 | 05:17 AM
openclasspro
yep
look in my sig i believe- shoot me an email i email ya links to pics of custom duals with magnaflow x -pipe on f150's - to show ure exhaust shop-phil
Old Jun 1, 2004 | 03:51 PM
Rambo's Avatar
Rambo
I just went with true duals this weekend, on my 2003 F150 with the 5.4L and I love it. It is certainly loud. The exhaust shop was supposed to put on some FreeFlow mufflers, one on each side, but get this, the mechanic forgot. So right now I just have headers, 2 cats, and then straight pipes back. This coming weekend I'm going to have him put the mufflers on, I asked them if I could wait a week and drive around without any mufflers just to see if I liked the sound, and I sure do
Old Jun 1, 2004 | 03:57 PM
froste's Avatar
froste
i'd leave it like it is, if u like it. That's the way i've got my 04, with the exception of just one pipe, not duals and i love it. IT SOUNDS GREAT !
