headders for an inline 6
Old May 29, 2004 | 10:46 PM
82F100SWB's Avatar
82F100SWB
The only difference between the EFI and carb heads is the EFI's have smaller fast burn chambers...
EFI manifolds flow decently, but, are not in the same league as headers, and if you plan on running true duals, the manifolds sound like, well, crap...
Old May 29, 2004 | 11:32 PM
77traded's Avatar
77traded
Some shops will have them, but 300 performance parts are hard to find. Go to ebay.
Old May 30, 2004 | 08:00 AM
fordinlinesix's Avatar
fordinlinesix
EFI heads have more manifold bolt holes, the EFI lower intake manifold has more bolt holes than a carb intake. Also, most EFI heads had air injection, so might want to plug those holes.
Old May 30, 2004 | 10:14 AM
77traded's Avatar
77traded
How could it have more bolt holes? Extra places to bolt it down?
Old May 30, 2004 | 10:45 AM
drive_old_ride_new's Avatar
drive_old_ride_new
Originally Posted by Silver Streak
There is no comparison between the EFI manifolds and real headers unless the head on a carb engine is lots worse than the EFI engine. I'm sure there is a big difference between a regular log manifold and the EFI manifolds so the difference between the EFI's and headers is less pronounced, but there is a very significant gain over EFI manifolds with headers.
Do you have any dyno comparisons that support those power gains? I'm in the process of bolting on the EFI exhaust manifolds this weekend. I based my decision to go with the EFI manifolds on many assertions on this board on how the EFI manifolds only flow about 3-5% less than tubular headers. If I'm not going to be happy with the results, I'd like to know now.
Thx - DORN
Old May 30, 2004 | 12:48 PM
82F100SWB's Avatar
82F100SWB
Compared to the stock carb manifold, the EFI's are a large improvement, just not as large as headers.
As for headers, Summitracing, Jegs, et-al carry 'em... Hedman part #89-300 fits most trucks with a 300(they have the 3/8" flange). Only listed as fitting 2wd, that's likle true 65-79, but, 80-up, they work just fine on 2wd and 4wd. They list for $140 at Summit.
Old May 30, 2004 | 07:59 PM
fordinlinesix
Yeah, there's more places to hold the intake manifold onto the head on the EFI head(only like 2 extra holes) I'll go look right now and get back with the correct info.
Old May 31, 2004 | 12:26 PM
lilpickup's Avatar
lilpickup
82F100SWB 96 I6 what year headers will match up with it I can't find header for that year, that part number is it 500-89300 and do you think it would work on mine motor.
Old Jun 1, 2004 | 04:17 AM
82F100SWB's Avatar
82F100SWB
It will fit your 96, but, it doesn't not have any emissions hookups. It will need to have oxygen sensor fittings welded in and soforth. You will also have to modify your alternator bracket.
Old Jun 1, 2004 | 06:18 AM
lilpickup's Avatar
lilpickup
for the alternator bracket how muck work is going to be needed to do to it, and on the header is it a one or two piece. thanks
Old Jun 1, 2004 | 09:39 AM
77traded's Avatar
77traded
The instructions for mine indicated modifying the alternator bracket and part of the stock intake manifold. Reality is the alternator bracket required no modifications and my offenhauser c series requires some serious trimming. Just my experience.
Old Jun 1, 2004 | 09:59 AM
broncr's Avatar
broncr
Originally Posted by 82F100SWB
... Hedman part #89-300 fits most trucks with a 300...
Sorry, I got annoyed with Summit's computerized answering - Are the Hedmans a single 2 1/2" out, or dual 2" ? Also, how's the starter clearance ( heat/proximity, R & R...)
broncr
Old Jun 1, 2004 | 06:06 PM
  #28
chuckman's Avatar
chuckman
hedman's site says dual 2.5" outlets, 1 1/2" primaries.
Old Jun 1, 2004 | 10:55 PM
  #29
82F100SWB's Avatar
82F100SWB
Dual 2.5" out, starter clearance is good once you get it in there, R&R can be a PITA... I did it a couple times with a big 'ol prybar to spread the pipes apart so it would drop out..
Invest in a late model reduction drive permanent magnet starter and a heat sheild, and you will never have to worry about that though.
Old Jun 2, 2004 | 06:20 PM
  #30
the_hetz's Avatar
the_hetz
