Sponsored by: Auxito
hum / buzz when hot
Old May 27, 2004 | 05:52 PM
sray1027's Avatar
sray1027
Question hum / buzz when hot
I have a 1998 f 150 5.4 4x4 with 109000 miles.
After a fews miles of driving and the motor is hot, When the motor is restarted there is a buzzing / humming that comes from or near the device behind the fueling intake body. The noise will stop after the motor is run a few min. Any ideas?? The motor runs fine and there is no engine light.
Old May 27, 2004 | 08:32 PM
Ultramagdan's Avatar
Ultramagdan
Hello sray1027 and Welcome to FTE! Sounds like the idle air control valve. Those things can make a ton of noise when they act up. You can try cleaning it but with that many miles I would replace it. They can cause your motor to run odd at times to.
Old May 31, 2004 | 12:17 PM
sray1027's Avatar
sray1027
would you go back with ford replacement part?
Old May 31, 2004 | 09:37 PM
Ultramagdan
No, any good auto part store will be able to supply you with the part you need. They are fairly easy to remove and install.
