Sponsored by: Auxito
Rear Springs
Old Jun 29, 2003 | 06:10 PM
LxMan1's Avatar
LxMan1
Question Rear Springs
Hey to all, has anybody noticed the drivers side lower rear leaf spring has twisted to the side on your truck? My 2001 F150 SuperCab 4x4 has. I saw a 99 the same way. It is just the bottom leaf and it sticks out in the rear about 1/2". Is this common or should I take it back to the dealer while the warranty is still good?
Jimmy
Old Jun 29, 2003 | 09:55 PM
John Ecker's Avatar
John Ecker
Rear Springs
Hi, Do you mean the bottom leaf sticks out to the side of the spring pack or straight out of the back without touching the leaf on the top? If it is to the side , I don't think it's a big deal for the short term but I would fix it especially if it's on warantee. If the leaf has a delrin pad on the top at the ends it will wear them out faster and eventually cause some noises. It is a 15 min. job and it may mean the u-bolts need to be torqued. John
Old Jun 30, 2003 | 05:38 AM
LxMan1's Avatar
LxMan1
Rear Springs
It is sticking out sideways, turned about 1/2 inch.
Old Jun 30, 2003 | 11:35 AM
f150-az's Avatar
f150-az
Rear Springs
my 97 has that same very problem on the left side. I know how to fix it but just have never got around to it. Basically you have to release the weight from the leaf springs then you can slide it back into place. Your prolly gonna have to take those U-bolts out though..........
Old Jun 30, 2003 | 03:06 PM
Racerguy's Avatar
Racerguy
Rear Springs
Usually you can just take a big beating implement and hit it back into place without loosening anything
Old Jun 30, 2003 | 06:15 PM
LxMan1's Avatar
LxMan1
Rear Springs
Dave, is this a factory defect? I have seen quie a few 97-up F150's this way.My 77 has never done this. nor has my dad's 89.
Jimmy
Old Jun 30, 2003 | 07:25 PM
Racerguy's Avatar
Racerguy
Rear Springs
I dont know why they get like that. Some of them do and some of them dont. Usually it is the bottom "overload" leaf that is out of place but on the earlier ones the bottom regular leaf would move too and Ford came up with a recall to fix that. Basically we just put clamps around them.
Old Jun 30, 2003 | 07:39 PM
LxMan1's Avatar
LxMan1
Rear Springs
OK, the next time I am by the dealer, I am going to have them look at it. It is the very bottom leaf that is crooked.
Thanks Dave,
Jimmy
Old Jul 1, 2003 | 01:10 PM
JeremyH's Avatar
JeremyH
Rear Springs
Are these hapening on the same corner of these vehicles?? If so, maybe the torque from the enging might be causing this. I know on Jeeps that the engine causes the jeep to sag slightly on the pass rear coil.
Might be something to consider.
Old Jul 1, 2003 | 01:18 PM
LxMan1's Avatar
LxMan1
Rear Springs
It is the drivers rear on the ones that I have seen. No real reason for doing it though.
Old Jul 4, 2003 | 10:46 AM
f150backinblack's Avatar
f150backinblack
Rear Springs
please let me know what you find out about this I just noticed mine a couple of weeks ago doing the same thing except on mine its on both sides I have a 98 reg cab the bottom leaf is out to the side about 1/2".
Old Jul 4, 2003 | 11:18 PM
LxMan1's Avatar
LxMan1
Rear Springs
Sounds the same as mine. I only see 1 band on the springs and it is pretty far up on the front side of the axle. It may be a week or two before I get out there to get it checked, but I will post my findings as soon as I get it looked at by my Ford dealer.
Jimmy
Old Jul 5, 2003 | 05:27 AM
f150backinblack
Rear Springs
thanks for the reply let me know what you find out I'll check around also and see what I can find out.
Old Jul 14, 2003 | 11:17 AM
LxMan1's Avatar
LxMan1
Rear Springs
Here is a picture of my drivers side rear spring
Well, that didn't work. I am adding to my 2001 gallery then.
Jimmy
Old Jul 16, 2003 | 09:59 AM
LxMan1's Avatar
LxMan1
Rear Springs
Well, I took it to the dealer today. They fixed it. The mechanic said that the gap between the u-bolts is a little wider than the springs and this gives them room to move. It at least looks better now.
Jimmy
