Coolant not circulating!
Old May 27, 2004 | 01:41 PM
faroffthetrack's Avatar
faroffthetrack
Exclamation Coolant not circulating!
I just changed the radiator in my 95' F-150 4.9 E4OD with a/c, now I have no coolant circulating, I've tried everything including disconnecting the heater outlet hose at water pump to bleed air from the system. I have heating, not water is coming out of the heated water bypass hose tough. I don’t want to drive it while it’s like this please help.
Old May 27, 2004 | 04:17 PM
MustangGT221's Avatar
MustangGT221
There might be some kind of blockage...look for a kinked hose around the engine compartment. Are you able to flush water through with a hose? Could be the water pump.
Old May 27, 2004 | 09:17 PM
chrono4's Avatar
chrono4
while there was no coolant in the system the thermostat could have locked up. i would check that before i went tearing into anything. hope this helps
afonda
22
Oct 30, 2016 07:09 AM
tweak1029
Mar 28, 2016 02:27 PM
kbarbee95
Dec 9, 2014 02:44 PM
MUDBUCKET
1978 - 1996 Big Bronco
Apr 27, 2014 08:42 PM
martinkrjr
1997 - 2003 F150
Apr 4, 2011 08:08 PM
