I have a 93 F250 7.3L DSL. The back two injectors on the left bank are leaking diesel fuel. Does anyone know how to fix this,
and is this something I can do myself.
You need to get a fuel return line kit($30), which comes with new injector washers, o-rings, lines, caps. You will need to remove the steel injector line from the injector, then pull off all of the rubber hoses, and then pry off the plastic caps. You will need to get a tooth pick and pull off all the o-rings and oil the new ones before installing them. then reverse the process to install. You need to let the parts man know if it is a turbo.
