Bed Extender Question
Old May 27, 2004 | 09:07 AM
RED04FX4's Avatar
RED04FX4
How do you remove the bed extender? do you have to unscrew the 2 screws or do you have to manhandle the metal clips?
Old May 27, 2004 | 09:20 AM
jmizell49's Avatar
jmizell49
As I recall, you press the metal clips in, and the extender comes right off.
Old May 27, 2004 | 09:25 AM
dcordle's Avatar
dcordle
I have one and that is correct. Press the metal clips and it comes right off.
Old May 27, 2004 | 09:52 AM
Mudlord's Avatar
Mudlord
You have to unscrew the two screws before you can depress the clips.
Old May 27, 2004 | 09:55 AM
dcordle's Avatar
dcordle
On mine you do not have to unscrew anything before depressing the clips. You just have to have it flipped onto the tailgate before depressing the clips.
Old May 27, 2004 | 10:35 AM
Mudlord's Avatar
Mudlord
dcordle - There are screws that can be tightened to prevent the clips from being depressed. They exist to keep someone from casually removing your bed extender. Yours may have already been loosened when you got your truck, but if you don't have the locking clips screws at all, you may want to have your dealer supply them.
Old May 27, 2004 | 10:57 AM
RED04FX4's Avatar
RED04FX4
thanks guys .... i'll tinker around more with it tonight!!
Old May 27, 2004 | 11:18 AM
dcordle's Avatar
dcordle
Okay... maybe. I'll take a closer look at it.
Old May 30, 2004 | 09:19 AM
Jrstera's Avatar
Jrstera
Exclamation
All you have to do is depress the spring clips on the outboard of the extender.
Another piece of advise, be sure you have the extender rotated properly so that the clips are down where you're unable to remove it when the tailgate is closed.
People (the bad guys) in Texas like them quite well and will try to take it off your hands, that's the second highest theft item on the trucks with the extender. The tailgate is first.
Old May 31, 2004 | 10:00 PM
GLankford's Avatar
GLankford
I've been trying to figure out how to secure the thing so it doesn't walk off. So you're saying that if you put it in with the clips up when extended, it can't be removed when stowed and the tailgate up?
Old Jun 1, 2004 | 09:01 AM
dcordle's Avatar
dcordle
The bed extender goes on with the tailgate down/open and the bed extender on the tailgate. When it's flipped into the bed and the tailgate closed it cannot be removed. So if you have a lock on your tailgate then your bed extender is safe.
Old Jun 2, 2004 | 09:02 PM
Jrstera's Avatar
Jrstera
That's right. The easy way to check is if you can squeeze the clips and take it off with the extender inside the bed, it's wrong. If that's the case, you flip it horizontally 180 degree's and it can't come off. Also, be sure to lock your tailgate. If they can't open it, they can't get the tailgate or the extender.....JR
Old Jun 2, 2004 | 09:57 PM
GLankford's Avatar
GLankford
Sweet! Thanks guys...
Greg
Old Jun 3, 2004 | 01:10 AM
KCFORDWKR's Avatar
KCFORDWKR
Does anyone know if a Bed Extender is avaliable for F250? If so, who makes them?
kengarchow
Jul 7, 2009 02:14 AM
04silverscrewfx4
2004 - 2008 F150
Feb 18, 2005 05:10 PM
lndshk
1983 - 2012 Ranger & B-Series
Apr 1, 2004 11:13 PM
toolman086
Nov 5, 2003 04:58 PM
