Oil
Old May 27, 2004 | 07:27 AM
SKIRYDR's Avatar
SKIRYDR
Oil
Just Curious As To What Weight Oil Everyone Uses In There Explorers? I Have A 96 4.0l With 130,00 Miles. Have Used 5w-30 In The Past, Started Using 10w-30. Any Problems With This?
Old May 27, 2004 | 07:37 AM
mason's Avatar
mason
I use synthetic (Mobil 1) 5W-30 in my '95 with over 140,000 miles. I believe most manufacturers went to lower weight oil for increased gas mileage. On a higher mileage engine I can't imagine that 10W-30 wouldn't be fine, especially during the summer.
Mason
Old May 27, 2004 | 07:44 AM
nhfire 77's Avatar
nhfire 77
i have a 98 5.0 with 150,000 and I use 10w-30 valvoline semisynthic for higher milage engines. I also experimented with Lucas Oil stablizer, i replaced one quart with it. Good results, quieter engine, less lifter/rocker sound. Yes that is prolonging the inevidable overhaul, but its cheaper right now.
Now that i have said that, someone will post a link to a site that is supposed to scare you out of using it b/c agitation leading to airation, personally I find it to be misleading. But I digress.
Old May 27, 2004 | 08:29 AM
Pig Pen Jr's Avatar
Pig Pen Jr
I used Quaker State 4x4 synthetic 10w-30 in my '99, year round. No more of the slight rattle when starting in the winter.
Old May 27, 2004 | 01:24 PM
devil421's Avatar
devil421
Mobil1 5w-20, newer vehicle formula, in my 99 SOHC.
Old May 28, 2004 | 10:28 PM
TomCarperNGiles's Avatar
TomCarperNGiles
Quaker State 4x4 synthetic, 5W-50. '91 rebuilt at 100,000.
Old May 28, 2004 | 10:37 PM
kev100's Avatar
kev100
Mobil 1 Synth ...usually 5w-30...but at 130K..I'm thinking about 10w-30.
Usually go 5-7K between changes...okay with the synth (so I hear).....many swear that even 15K is okay with that stuff.....(it cost enough...it otta')
Anways....no lub problems so far.
98 4.0 SOHC XLT
Old May 29, 2004 | 04:02 AM
stonem77's Avatar
stonem77
I wouldn't use 5w oil in a lawnmower. LOL even though it is reccommended in some vehiles the minimum i'd use is 10 w 30. I had an 81 cutlass that ran 15w40 year round and the body fell off of it before the engine quit. (over 380000 kms on engine) Even when it was 40 below she'd still crank over LOL
Old May 29, 2004 | 08:58 AM
nhfire 77's Avatar
nhfire 77
well you have a point about the 15w-40. At the fire department i work at every vehicle from the big engines,ladders,ambulances, to the staff cars(crown vics and explorers) they all get 15w-40. Its labeled "heavy duty fleet oil." never had an engine failure.
Old May 30, 2004 | 07:57 AM
BrianJ77's Avatar
BrianJ77
Been running Pennzoil 5W-30 in my 99 SOHC X for 47000 miles. I sometimes get some lifter noise on initial startup or on a hot restart after it has been sitting for about 30 minutes. No problems to date, though. Still worried about the dread chain tensioner though.
Old May 30, 2004 | 09:31 AM
devil421's Avatar
devil421
I think we are all worried about that. Im creepin up on my 72K mile point where its my problem. I think Im gonna get the tensioner recall done AGAIN just to be safe.
Old May 30, 2004 | 07:17 PM
srercrcr's Avatar
srercrcr
I wouldn't think the dealer would do the recall unless it exhibits the chain noise.
Old May 31, 2004 | 08:12 AM
BrianJ77's Avatar
BrianJ77
At least its good to know that if, by very bad luck, you have to buy your X a new engine due to tensioner failure that Ford has fixed the problem in the new engine. I drove an X with the pushrod V-6 and I must say that I really like the power the SOHC engine delivers over that of the pushrod motor. I guess my worry that the tensioner will fail is the price I pay for lots of power.
joe truck
1983 - 2012 Ranger & B-Series
Nov 9, 2011 05:23 PM
Paul T
Dec 31, 2008 11:35 AM
Hidalgo
Sep 6, 2005 08:27 AM
kameronth
17
Feb 19, 2005 04:41 AM
Beaned
Aerostar
Jan 10, 2004 04:00 PM
