ok ok psom error
Old May 26, 2004 | 07:50 PM
mroldfart2u's Avatar
mroldfart2u
Question ok ok psom error
Ok my head is a swimmin.... been readin' posts but I've got something different than I've found so far... if I try the reset button whill turning the key to run it says E 08 0, which I've understood to be no resets ect.. but the problem with my unit is it does the sweep, then the led odometer goes thru the led self test, then reads Error and stays that way. When I take off the speedometer instantly pegs out. although the cruise control ect seems to work fine... Time to look for another cluster? Thanks in advance...
p.s. never had ANY luck posting on any other forums when I have tried to get help on anything
