1978 - 1996 Big Bronco
Electrical system
Old May 26, 2004 | 06:53 PM
Jaken86's Avatar
Jaken86
Electrical system
im havine a problem with starting my car, im getting power to my starter, sometimes it just sounds like an electrical clicking or it tries but fails to turn over. ive ruled out my battery, battery cables, cable ends ,and my starter (new). headlights dome lights, radio ,and everything else in the cab work. just has problems starting. am i screwed? or has this happened to someone before. i havent changed my cylenoid. its a 1986 ford fullsize 302 eddie buaer edition, any help will be appreciated. if anyone uses IRC (internet relay chat) i opened a chat channel on efnet called #Bronco if they want to chat about broncos
Old May 26, 2004 | 07:14 PM
ubermich's Avatar
ubermich
The only time that's happened to me is when the battery was dead. The relay clicks because there isn't enough power to keep it open... Did this problem suddenly occur?
Old May 26, 2004 | 07:17 PM
Jaken86's Avatar
Jaken86
nah
it just started happening recently it i can some times get it to start when i use a 200 amp engine start of my battery charger
Old May 26, 2004 | 08:00 PM
body9599's Avatar
body9599
I second ubermich's diagnosis...had the same problem...also changed the solenoid, but didn't help. Turned out my battery wasn't holding a charge. Popped a new one in there and worked great. So...try charging your battery or have it tested somewhere and replace as necessary. as a note: my problem also had sudden onset.
Old May 26, 2004 | 08:09 PM
ubermich's Avatar
ubermich
Autozone tests batteries for free
Old May 26, 2004 | 08:20 PM
Jaken86's Avatar
Jaken86
yeah but
why wouldnt it start with a battery 200 amp engine start? it would still turn over
Old May 26, 2004 | 08:23 PM
ubermich's Avatar
ubermich
All I know is that was the problem with mine (twice, two different vehicles), and it only takes a few minutes to pull the battery and take it down to autozone to have checked. If it has no charge, they'll charge it for free, if it doesn't work still, you know for sure that's not the problem, if it works for a while then starts up again, you know your battery is biting the dust...
Old May 26, 2004 | 08:25 PM
Jaken86's Avatar
Jaken86
hmm i already switched out the battery and i was gonna change the solenoidbut i dont know thx for the help
Old May 26, 2004 | 09:06 PM
Jaken86's Avatar
Jaken86
well ****
hey man you were right, turns out the battery i had and the extra i had were turds. i put a new one in and it runs great. thanks for the help
Old May 26, 2004 | 10:06 PM
ubermich's Avatar
ubermich
My pleasure.
/me walks out the door a half-inch taller
