I-Beam Indentification
Old May 26, 2004 | 02:17 PM
HardFordCore's Avatar
HardFordCore
I need some help identifying the I beams on my 66 F100. The truck was converted to power front disc brakes using later model I beams and spindles. I am considering ordering some dropped I beams but want to be sure of getting the correct parts (kingpin size). The part number on the right front I beam is D8TA-8-CA. Can anyone nail down what model truck this I beam came from? Thanks.
Old May 26, 2004 | 04:11 PM
Mike G's Avatar
Mike G
Looks like somebody used a 1978 as the donor truck for your beams. I recall that the kingpin size was in issue for 65-72 and then they changed from 72-79. If you are getting the drop beams, don't they offer a generic beam for 65-79 and tell you what size pin to use?
--Mike
Old May 27, 2004 | 08:12 AM
HardFordCore
Thanks Mike,
What I am trying to determine is what size king pins are used with the spindles on my truck. The listing for I Beams are one set for F100's and the other for F150 and up.
Old May 27, 2004 | 09:07 AM
Mike G's Avatar
Mike G
At some point in time over their life, the F100 was changed to a F150 designation. See if you can find FordBoyPete, he can dump all kinds of info on you regarding these.
--Mike
trik57r
May 8, 2017 07:58 AM
44vulcan
Nov 27, 2015 04:37 PM
PlumCrazy*
Jun 26, 2014 10:10 PM
truckerdead
Apr 9, 2014 06:34 PM
elyons1970
Apr 25, 2011 01:41 AM
