77 highboy brakes ????????
I have a problem with the highboy I was hoping you guys might help me with....
It has been puking brake fluid out the cap since i got it, I figured it would go away after i did all the brakes but it hasnt????
I replaced the master cyl. the rotors,callipers,rear wheel cyls, shoes & pads, and hardware. There is nothing else to replace but the booster and the prop valve
When I bled it it had good pressure and no air.
But it continues to puke fluid from the cap...
The cap has a good seal and the spring is tight..
Any help would be appreciated
John.
