Valve Cover Torque Settings
Old May 25, 2004 | 06:51 PM
macgyver1's Avatar
macgyver1
I have a 1992 Ford Ranger 4.0L V6. The valve covers are leaking and I have purchased factory gaskits ($60.00/pair OUCH!) but need the torque settings for the valve cover bolts. I was told by a surly Ford mechanic that it is 18 ft. lbs., but that doesn't seem right. I would appreciate someone who knows for sure what the proper setting is.
Old May 25, 2004 | 08:51 PM
Ken00's Avatar
Ken00
My 96 manual says 89 in/lbs.
Old May 25, 2004 | 09:19 PM
hreed's Avatar
hreed
The 92 Haynes manual says:
Step 1 36-60 in/lb
Step 2 Wait two minutes
Step 3 Retighten 36-60
Make sure you look at the spreader washers and put them back in the same place. A lot of times just tightening the bolts to the proper torque will solve the problem. And start from the middle of the cover and work towards the ends. The mechanic was off a little on the torque. You would have probably had to invest in an easy-out if you put that much torque on those bolts. Good luck.
Old May 25, 2004 | 10:04 PM
macgyver1's Avatar
macgyver1
Wink
I had a feeling that is what he wanted to accomplish... Breaking off the bolts. Thanks for the info...
reloaderbill
Oct 19, 2016 09:59 PM
canuck2a
2009 - 2014 F150
Jun 12, 2016 11:42 PM
1973supercamper
Apr 28, 2016 08:38 PM
twigs
Jul 16, 2015 01:54 PM
DutchmanAZ
18
Sep 19, 2014 01:32 PM
