Sponsored by: Real Truck
Trailer wiring
Old May 25, 2004 | 05:17 PM
jcullom's Avatar
jcullom
Trailer wiring
I've determined that I'm not getting any juice from my truck (2001 F250), trailer connection for the trailer left turn & left brake light. I looked for a fuse that might control just that function but found none. Is there anything I should look for besides a bad wire? It has worked in the past, just not now. Thanks for the help.
Old May 25, 2004 | 06:29 PM
pipercub's Avatar
pipercub
I had a problem like that once. Sometimes the plug gets a lot of corrosion and junk in it. Try cleaning it with WD40 or blow it out with some compressed air. Hope that works for you.
Old May 25, 2004 | 07:24 PM
TJC1989's Avatar
TJC1989
Corrosion, most likely, somewhere. Have to track it back to the energy source, and check the wiring. The most likely culprit is the connector at the back. If you are just going by the fact the trailer lights are not on, check the trailer wiring, too. But if you are testing at the connector with a test light, and still don't have power, then you have to back track it to the front, and where it gets its power. Not fun. But check the easiest first, the connector. It gets most of the weather abuse.
Old May 25, 2004 | 08:07 PM
johnsdiesel's Avatar
johnsdiesel
I had the same problem with mine recently. My left turn signal was not working. The wire was dead all the way up to the engine. Rather than run a new wire from the front of the truck I ran a new wire from the left turn signal light at the rear of the truck. If you go that route you shouldn't have any problems. That's how wires used to be run before trailer wiring was a standard option in vehicles.
HERE is a diagram to help you out.
Old May 25, 2004 | 09:25 PM
Steina's Avatar
Steina
CO River Rat
On some vehicles with computers and light status panels, you can cause SERIOUS (read expensive) damage by tapping into the taillight circuit. Don't know if this applies to jcullom's '01 F250, but it wouldn't hurt for him to check before doing this. In the ol' days it didn't matter, but today who knows.......
Old May 25, 2004 | 09:28 PM
johnsdiesel
That's the first I've ever heard of this. It shouldn't effect the circuit at all. As long as the turn signal continues to function normally (i.e. speed of signal does not change) there should be no problem.
Old May 25, 2004 | 10:03 PM
Steina's Avatar
Steina
CO River Rat
The following is a quote from a tow vehicle parts supplier:
"Today's vehicles have more electronic features than ever before. New advancements include on board computers, cruise control, ABS brakes, air bags - systems that require more electrical power and more protection.
When you connect a trailer to a modern vehicle with sophisticated electronics you need to be aware that these features can also lead to more potential problems. Failing to use the proper wiring system for your tow vehicle can have many unfortunate consequences. An inadequate wiring system can cause an overload, resulting in blown fuses and potentially damaging sensitive, and expensive, electronic devices on your tow vehicle".
I wasn't aware of this either until recently. Again, it may not apply to an '01 F250 but if it does..............better safe than having a lighter wallet.
Old May 26, 2004 | 12:01 AM
TJC1989's Avatar
TJC1989
Does make sense. Lots of cars have sensing capability that senses a tail light bulb burned out, or stop light bulb, and have a dash display advising which light is burned out. It takes a certain level of sophistication with electronics to do that, so overloading a particular circuit might wreak havoc on the system. My wife's Accord, and then her Camry had that. However I don't know either way on these Ford pickups. I recently added some extra backup lights to mine, and tied in to the regular backup light wiring to power them. Hope I don't hurt it. So far so good. But then they probably draw less current than a trailer.
Old May 26, 2004 | 04:58 AM
johnsdiesel
I guess my 1997 isn't that "sophistocated." Good information though. Thanks. Research deserves reputation points I think (positive of course!).
Old May 26, 2004 | 09:46 AM
fireman28's Avatar
fireman28
Check the back of the trailer plug on the truck and make sure that the wires are making good connection. I had the same issue on a different truck and used a test light and found that I had power to the connector just not through it.
Old May 26, 2004 | 10:25 AM
jcullom's Avatar
jcullom
Progress.....
Thanks guys for all the help. This morning I took the connector off the wiring harness & determined with a continuity tester that it is ok. Then I used a voltage tester & found that in the harness connector where the trailer connector wires plug into, the pole that feeds the left turn blinker isn't getting juice. All the others are, so it's either the harness connector or the wire. Now, my question is, does anyone have an idea where the trailer wire harness begins in the engine compartment. If I could find it, then I should be able to narrow things down a bit further.
Old May 26, 2004 | 12:30 PM
jcullom's Avatar
jcullom
Duh........
Jeez, do I feel like an idiot. I said earlier that I looked for a fuse covering just the trailer left turn lights. At first I didn't see one in the book, but after a second look, there it is! I guess I need new glasses. Anyway, it's in the fuse panel up front. Number 1 fuse too. Oh well, at least I didn't have to tear out the wiring. Thanks again for all the suggestions.
John
