Lifter noise...
Old May 31, 2004 | 08:47 PM
77traded's Avatar
77traded
I tried a little tranny fluid and it got a little quieter. That was before I changed my oil. Now it makes that noise again. Should I just get some stop smoke to thicken up the oil or run the cleaner?
Old Jun 1, 2004 | 08:16 AM
SPROCKET's Avatar
SPROCKET
At 70k miles I switched from running regular 10/30 to Full Synthetic Mobil1 10/30 and my lifters haven't made a peep at 65k miles later, I'm at 135k now.
Old Jun 1, 2004 | 03:13 PM
javi2001's Avatar
javi2001
Synthetic oil can be used on I6 engines??? there is no problem?? Advantages???
Old Jun 1, 2004 | 06:53 PM
natemail's Avatar
natemail
I had about the same problem about a year ago. Replaced lifters, adjusted rockers, everything under the sun. It wound up being a spun bearing on the crankshaft, with the conrod all egged out and the bearing totally crushed, it had been that way for a year and a half though, gotta love that.
Old Jun 1, 2004 | 08:34 PM
77traded's Avatar
77traded
Mine just got a lot quieter. Borrowed a timing light and set the timing. It was at about 15adc and now is at 10bdc. I adjusted the carb some more, I think it is almost tuned. Also should I expect it to burn out on dry pavement without a problem? It gets a to speed in a hurry, but it doesn't seem to burn out easily. my mods are in my sig.
90turbo1
Modular V10 (6.8l)
Jan 17, 2015 02:34 PM
Schnurrbart
Nov 26, 2014 08:17 PM
Schnurrbart
Nov 25, 2014 10:51 AM
timbersteel
Oct 16, 2014 11:57 PM
normalmike
Nov 6, 2013 11:48 PM
