Lowering 1997 4X4
Old May 25, 2004 | 03:42 PM
FoMoCo136's Avatar
FoMoCo136
Lowering 1997 4X4
I want to lower my 97 4X4 Expidition. It has torsion bars on the front. How low will it go and in an extream lower will it align back up? I plan to lower it at least 3" or more.
Old May 31, 2004 | 02:45 PM
FoMoCo136's Avatar
FoMoCo136
Has no one done this? I guess I can just start cutting and let you know. I cannot find any aftermarket parts for this. I find that hard to believe.
Old May 31, 2004 | 02:59 PM
Rod it and Haul it's Avatar
Rod it and Haul it
Why would you want to lower a 4x4???????
Old May 31, 2004 | 06:30 PM
tonum24's Avatar
tonum24
The question should be why wouldn't you lower a 4x4? Offroading is the ONLY reason to keep it stock height or even raising it. Go to WMS racing .com or even better I saw another site posted a few days ago that was cheaper. You'll get new torsion keys and shorter springs. Your expy will handle better,brake shorter, ride less bouncy and look better. Getting in and out is easier too. The kits are usually 2" front and 3" rear. If you go lower than 3 inches you will need "shorter" shocks and drivetrain angles could cause problems too
Old May 31, 2004 | 08:28 PM
Rod it and Haul it
Why would someone buy a 4x4 without the intentions of offroading??
Old May 31, 2004 | 08:29 PM
tyger25's Avatar
tyger25
What are you tryng to achieve? Are you looking to lay frame, or reduce a couple of inches for performance and handling? Is your expy an XLT or do you have LLS?
Old Jun 1, 2004 | 12:42 AM
f150onspinners's Avatar
f150onspinners
i herd its better not to lower a 4x4
Old Jun 1, 2004 | 11:28 AM
tyger25's Avatar
tyger25
There is nothing wrong with lowering a 4X4. You are just losing ground clearace. In fact, if your rig never leaves the road, it works to your advantage, by lowering your center of gravity, decreasing your chance of a rollover.
Old Jun 1, 2004 | 08:15 PM
FoMoCo136's Avatar
FoMoCo136
It just happens to be a 4X4. I want to lower it because it looks good. No other reason. My wife will never go off road anyway. I am going to change wheels and tires, Lower it about 2 to 3 inches, and maybe some minor mods to the powertrain. I have had this along time and I am ready for something new. The thing that gets me is this tortion bar front end. Not sure if it will go very low.
