Front Output Seal
Old May 25, 2004 | 01:18 PM
voodoosmooth's Avatar
voodoosmooth
Front Output Seal
1997 F250 PSD 7.3L with the E40D tranny. I took my truck and had the trasnmission worked on because I was spewing tranny oil up front after a long haul with the boat. $1200 to repair. Still leaks, just not as bad. Took it back into the tranny place and they said it was the front output seal. They swapped it out, said give it a week and see if it is still leaking. Sure enough, I'm leaking.
Anyone have this problem before? What fixed it? I'm not an expert here on trannys. Shouldn't this problem be solved by now with my tranny shop?
Thanks.
