I have a 1990 F2504x4 that I am putting a flatbed on,
and just need the dually wheels on the back if I buy the 4wheels for the back will they just bolt on?? somebody said I need an adapter but I already have the long wheel studs and the full-floater axle so I have the same axle as the dually trucks so will the rear duallys just bolt on???
I need to know solid information please,from someone who knows.
Having a floating axle doesn't necessarily mean the weight rating is the same as a dually axle. Better research that a little closer before you end up with a busted axle housing.
alright I need to know from womeone who HAS done it.
the full floating axles are the same between 250 and 350 and they are the same widths if they are full floating.
