Leaking Sunroof Problem Solved
Old May 25, 2004 | 09:13 AM
18fan's Avatar
18fan
Exclamation Leaking Sunroof Problem Solved
After taking the 95 Explorer to the dealer to find the cause of the leak. The rubber gasket around the glass panel had become hard and was not sealing. After 94 you cant buy just the gasket and the you have to purchase the whole panel for $488. I managed to find 1 at a local salvage yard that was like new for $163. If anyone else has a problem with water leaking , check the seal around the glass panel. Hope this helps.
Old May 25, 2004 | 08:28 PM
srercrcr's Avatar
srercrcr
There's probably some aftermarket suppliers that have this.
Glad you got it fixed.
Old May 26, 2004 | 08:19 AM
silvermaxd's Avatar
silvermaxd
was it making a dripping noise cause I'm hearing a dripping noise when driving in the rain. Nothing is leaking in but I'm just hearing dripping
Old May 26, 2004 | 11:00 AM
18fan's Avatar
18fan
It started out as just a few drops and finaly got to the point it was a steady stream.This all happened in just a few weeks. It had one of those deflectors installed in front of the sunroof when we got it. Thats the first thing they told me to take off since it traps all the crude on the roof and deposits it right on the seal in the front. Thats the only place the seal was bad, in the front corners and there was alot of dirt and debris trapped in the channel under the deflector.
jrmwilson
19
Mar 24, 2013 11:49 PM
sf0606
2004 - 2008 F150
May 10, 2010 09:02 PM
Move over I'm coming
Jun 4, 2009 04:03 AM
ExpoBoi99
Mar 13, 2004 04:34 PM
McLeod
1978 - 1996 Big Bronco
Mar 12, 2003 10:48 PM
