PSD Questions
Old Aug 1, 2001 | 06:55 AM
Route66's Avatar
Route66
PSD Questions
As a new PSD owner (2001 excursion) I have two questions. My Ford mechanic told me I do not have to fill the fuel bowl when changing the fuel filter due to the electric fuel pump. Is that true? Also what's the thoughts on diesel fuel additives? He told me "not" to use anything. Thanks...
Old Aug 1, 2001 | 02:30 PM
alanscott's Avatar
alanscott
PSD Questions
He's right about the fuel filter, I have never had to refill the bowl.
Stay away from fuel additives that contain alcohol, the stuff that says "Removes Water". It surrounds the water and then lets it pass through the injectors. I use an additive that is a cetane enhancer, it starts easier and I get better milage with it. I thought about buying an Excursion, but it's a little on the small side
alanscott
[link:ford-trucks.com/users/alanscott/|http://www.ford-trucks.net/users/alanscott/clubftesml.jpg]...Click!
Old Aug 2, 2001 | 07:15 AM
catfish's Avatar
catfish
PSD Questions
The dealer was correct the filter can be changed or drained and the filter housing will fill itself, no more manual pumping and bleeding lines and swearing! There is A bleed valve at the rear of the fuel filter housing, there is A bleed tube hanging down the right side of the engine, I extended mine with A piece of fuel line (rubber hose) which allows me now to catch the fuel, this traps water that may be in the fuel, It also acts as A drain for the fuel housing when servicing the fuel filter!
Old Aug 2, 2001 | 05:02 PM
NoWake's Avatar
NoWake
PSD Questions
Route66
The fuel filter question was already talked about no reason to beat a "dead horse". The fuel supplement however is a good question. The dealer that I bring the truck to recomends using "Power Service Diesel Fuel Supplement". Up until last winter I did not use any additives, that was until my fuel gelled up. I took me 5hours to get the thing running again...that time included waiting for the tow truck to bring me to my neighbor's heated gurage. So, from that day everytime I get fuel in the winter I always use it.
They also have a product called 911, it is used for de-gelling the fuel. I have never used it so I do not know much about it.
Now, if you live were it never freezes then you really don't need a supplement for gelling. But do not forget about it when you go on that yearly ski trip......
Stay away from alcohol!
Rick
Old Aug 3, 2001 | 10:04 AM
Route66's Avatar
Route66
PSD Questions
As for additives has anyone used Performance Formula from Stanadyne?
Old Aug 4, 2001 | 11:19 AM
bigfordman70's Avatar
bigfordman70
PSD Questions
I've tried Stanadyne and P/S, never could tell any milage differance, but I do run the Power Service in the winter.
BFM
Recycle...crush a chevy
Old Aug 6, 2001 | 09:29 PM
SctS's Avatar
SctS
PSD Questions
After getting a batch of bad diesel on a trip back to the mid-west, I picked up the Performance Formula from Stanadyne and use it when filling on the road. When around home I usually fill at the same station and don't worry about the additive.
I can't say that I've seen a big difference when using the additive, but I've also not had a problem with lower quality/cetane fuel (yeah, could be concidence - but it's cheap enough that it's worth the piece of mind if nothing else).
Old Aug 6, 2001 | 11:31 PM
argve's Avatar
argve
PSD Questions
I use the Performance formual, makes a slight difference in mine. Raised it .4 mpg, starts easier and lubes the fuel system. I live here in northen Ind, and getting good quality fuel is a problem. Everyone I know around here runs it and is very happy.
1991 F350 CC Dually 7.3l, E40D, Soup bowl removed, K&N
Old Aug 22, 2001 | 08:38 PM
mattshddisel's Avatar
mattshddisel
PSD Questions
tomorrow im buying a 96 hddually 1 ton p/s disel.
its a beutiful black 4 door w/a removable power winch for front or rear,a brush guard w/off road lights,and many other extras.
it has 87,000 miles and is a automatic.
im looking for any friendly advice that will help me make my babby last longer.thanx.matt
Old Aug 23, 2001 | 02:18 AM
Stax's Avatar
Stax
PSD Questions
