ok this si one of 3 question i will post that if you dont mind, please review and reply to. this one reguard tiree size. the truck:1994 ford ranger v6 4.0 xtl, single cab , standard suspension-no life, however i have thay lame "stick bug" effect int eh back where the tail end sticks up a bit, but anywho, with this set up, i want to throw on some large, oversized tired, i spoke to a auto shop personel who told be some " 31's " woudl do the trick, does that sound right? what is the exact size? i have 15 inch wheels, currently with p235 75 r15 in all 4 locations, but i want BIGGER heheeh, however i dont want it to rub. ok guys, here is your task, what do you recommend?
please proceed to next post
Alex
I have put 31 10:50's on my 97 without any trouble but it had the STX package and I am not sure if that has a little highe ride or not. But have seen others with 31's without rubbing.
i had 32x11.5r15s on a 83 ranger i put about a 1/2 in lift on it (old shredder blade) and stuffed the shocks (bad idea) , all i ever did in it was haul junk to the junk yard and i got tired of it going to the ground , on the front i had 235-75s (no fenders so i dont no if they would have fit )
I have 32 11.50 R15's on my 93, no lift. I'm assuming you have a 4x4. They fit just right, no rubbing at all. I think the issue with getting 32's on is the wheel size, not sure what the minimum width a 32 will fit on is, I just know that mine were wide enough, and I don't remember off hand what width they are. (I did have to zip tie a loose piece of the plastic wheel well on the drivers side where a plastic bolt was missing) I've got pictures in my gallery. I hink they make the truck look real good. I've gotten lots of comments from people about them, lots of people don't realize they will fit.
Wahoo, you guys rock, thanks alot. i will check out eh 31s and 32s, right now i got 235 75 r15s on. however my ranger is not 4x4 as much as i woudl love it to be, i feel like a sissy now, haha. ok thanks alot i wrote down the numbers you guys recommended and i will check it out tomarrow. after teh tires are done and the custom interior is done iw ill start a gallery so you can see what my ride it.
