Budget FE Plan? Ideas
Old May 24, 2004 | 07:47 PM
TheImpaler's Avatar
TheImpaler
So, my motor is almost done and hopefully it will function well. : ) My dad is going to build a 390 for his 67' at some point, so we'll have his original 352 as an extra. I was kind of toying with the idea/dreaming of building a budget FE. As much porting/polishing, weight reduction, and general improvement as I/we can do ourselves. The basic idea will be to build a screaming 352 for cheap. Whether it's a good, much less feasible idea or not remains to be seen - for now I am just dreaming.
Why do I bother telling you guys? I was hoping you could provide some suggestions as to what kind of vehicle would be a good candidate for this. I am in the southwest, so very few cars have rust problems or the like. Would a motorless Fairlane be easy to find? Mustang/Cougar is probably out, but who knows. What do ya'll think?
-Patrick
Old May 24, 2004 | 09:15 PM
shrike's Avatar
shrike
try a ford maverick, Mercury comet, or Falcon, Back in the late 60"s early 70"s the Ford guys use to use these cars to contend with the small block chevy vegas, they are not to heavy, and with the 352 should give you a good cid/wieght ratio. it should lay it down and it all depends on what you want the vehicle to do. Hope this helps, I really told my age on this one.
Old May 24, 2004 | 09:51 PM
TheImpaler's Avatar
TheImpaler
Just the kind of info I was thinking of - did Falcon's ever come with an FE? Maybe a 332 or a 352?
-Patrick
Old May 24, 2004 | 10:18 PM
shrike's Avatar
shrike
not to my knowledge, I had a 65 but it had a 6 cyl, and I later put a 289 in it, I believe they came with 289's on special order, the only problem with the falcon is the amount of tire you can put in the rear, they had really narrow rear wheel wells, unless you would plan on tubbing the rear, but they are super light cars. shrike
Old May 24, 2004 | 11:19 PM
fordman428's Avatar
fordman428
i dont think falcons came with FE's, most had inline 6's, some had 260 V8's and a few later ones had 289 V8's. i dont know how hard it would be to cram a FE in a falcon, im sure it would take some modifacation, but if you did it would go like he**, there not that big of cars compared to the fairlane and galaxie.
Old May 24, 2004 | 11:25 PM
fordeverpower's Avatar
fordeverpower
I myself have a 390 and want to find a 1968 mustang for it.
Old May 25, 2004 | 09:55 AM
Mike G's Avatar
Mike G
Fairlane would be the easy choice as those were available with the FE already. The others are a snug fit between the shock towers, but there's always the MII independent suspension upgrade to take care of that
--Mike
Old May 25, 2004 | 11:20 AM
durk's Avatar
durk
just to tell you my dad's falcon has a 351 in it. it took alot of mods. to get it in there, so you would have to be really good to get an fe in.
fifty-two_f1
WTB - Parts & other
Nov 29, 2016 08:10 AM
Ziegelsteinfaust
64
May 14, 2011 04:54 PM
scmagner
Jan 25, 2011 01:19 PM
Annihilator
17
Apr 19, 2005 09:11 PM
Justoldbobo
Dec 7, 2003 11:28 PM
