transmisson shifting
Old Aug 1, 2001 | 09:13 PM
bbarton's Avatar
bbarton
Old Aug 28, 2001 | 06:27 PM
therigwelder's Avatar
therigwelder
does the 6.9 have a vacum regulator valve like the 7.3 for trans. shifting ? If so is it located on the IJ pump? how is it adjusted?
also i have an 86 f-250 will the 7.3 drop in in place of a 6.9 with auto tranny?
Old Aug 31, 2001 | 09:09 PM
bigtex2's Avatar
bigtex2
The 6.9 and the 7.3L are virtually the same, they will bolt right up, I own an 88 that had a 7.3 in it, i put in a 6.9L that i rebuilt. No problems. The vacuum actuator for the shift point is located on the Drivers side of the Injector Pump, little black dealy w two screws into the pump housing, has slots to move the actuator forward or reverse. Loosen off the screws, i believe that moving it forward will increase the max rpm to shift the trans at higher speed or rpm, and moving it back to the firewall will reduce the shift point to lower rpm, or speed, to drive around town, and not scare the crap out of everyone as you scream by at 3000rpm in 1st gear!! LOL
BigTex2 88F250, 6.9L, 4x4, Stinger kit, c6, 4.10's, lockers, the old girl just wont die, 850,000miles and still counting!!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
