HELP: Question about tank selector valve
Old May 24, 2004 | 02:12 PM
meck1's Avatar
meck1
I've got an '87 F250 with the 300 engine and dual tanks. The selector valve for the tanks, mounted on the driver side frame rail, is the six connector, non-electric type. Mine is hooked up with the fuel return lines next to the frame rail and the supply lines toward the middle of the truck (away from the frame). The Haynes Manual shows a diagram with the lines reversed from this. Can someone tell me what is correct? The truck has been running fine this way for three years. I only noticed it when I went to check one of the in-tank pumps, pulled what I thought was the return line, and got a face full of gas.
Thanks,
Meck
Old May 27, 2004 | 08:58 PM
bob arrington's Avatar
bob arrington
if you truck runs fine and every thing works, dont fix it ,bob
