Is my computer shot?
Old May 24, 2004 | 08:11 AM
Harleymw's Avatar
Harleymw
Angry Is my computer shot?
87 E150 with a 302 died at 40mph and wouldn't restart. Since then I have a new ignition module, new pickup coil in dist, new cap and roter, newer plugs, new TPS.
Checked timing chain, checked fuel pressure ( 35-40 psi, holds pressure during acceleration), have spark, have power to injectors (tried starting fluid while cranking, doesn't fire).
Ran codes several times, one time got a code for TPS, replaced it. One time got a code for secondary air system, have checked lines and valves, they appear to be OK.
If I advance timing to 30 btdc it will start but runs poorly, if I set timing correctly (spout disconnected, 10 btdc) it won't start. The marks on the dampener are correct at tdc on #1 cylinder. I am running out of ideas.
Old May 24, 2004 | 08:40 AM
Bob Ayers's Avatar
Bob Ayers
How did you check the timing chain?? It sounds to me like it has jumped time......
Old May 24, 2004 | 08:48 AM
Harleymw's Avatar
Harleymw
Put # 1 cylinder at TDC and marks on dampener line up at 0 degrees. Rotor is aproaching the #1 post on the cap, and there is less than 3 degrees of play on the crank before the rotor starts to turn.
navag8ter
1983 - 2012 Ranger & B-Series
13
Oct 5, 2013 08:07 PM
bigjonv
May 29, 2012 05:34 PM
Dan92668
Feb 29, 2012 01:13 PM
G2IC_Wraith
4 Cylinder Engines
23
Jun 25, 2007 09:29 AM
bud driver
Oct 3, 2004 04:36 PM
