need help! F250 351w
Old May 24, 2004 | 06:04 AM
pilfit's Avatar
pilfit
Unhappy need help! my F250 351w has an odd comuter setup, nead to find wiring diagram
I have a 1985 F-250 with a 351w 2bbl carb but it has a TFI-IV ignition system
the carb and ignitoin is computer controld but when I asked the ford dealer near me if they had wiring diagrams for it they said there was never a 85 F-250 351w with a set up like that I have asked some auto repear shop near me and they say the same thing. I'm trying to track down a short some where in the wiring harnes but I cant find any info on this setup. Can any one help? and any one seen an F250 like this?
Old May 24, 2004 | 11:53 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Get a truck repair guide that contains wiring diagrams. Also look in your public library for the 'Michell Manual' repair guides for your year truck. They list every ignition/fuel system combination possible.
It could also be that a 351 was not the original engine in that truck. I believe '84-'86 300 sixes came with carburetion and TFI-IV. There should be the letter 'G' in the VIN if it had a 351 originally.
Thanks for joining us at FTE!
Old May 24, 2004 | 03:31 PM
pilfit's Avatar
pilfit
I checked that, it is the original engine and the problem I'm having is my wiring dose not match the ones in those books. butt after reading some more on this forum I think I might have found my problem. But this truck still has an odd setup from what i'v bin told the EEC-IV was only on the EFI engine not the carberated 351w.
Old May 24, 2004 | 03:58 PM
fai4g63's Avatar
fai4g63
I know the 351HO 4V motors had duraspark II. The 2V 351's used the TFI ignition system.
Old May 25, 2004 | 08:46 PM
rander101's Avatar
rander101
Pilfit:
Your dealer and the shop are incorrect. If they are not, you and I have two rare trucks because I have one with exactly the same setup in my driveway. As near as I can determine, the 1985 F-250 351W 2V pickups were fitted with EEC IV (TFI) and feedback carbs. The 352W HO 4V were fitted with the DuraSpark II system. There is a wiring diagram for the EEC IV setup in the Haynes Manual #880: Ford Pick-ups & Broncos 1980-1990. It is included in the back along with several other wiring diagrams and it takes some searching through the diagrams to identify the correct one. The current Haynes Manual is for Pick-ups and Broncos 1980-1996 and I am not sure it has the correct wiring diagram in it. You may have to located an old edition to get the correct one. There are several listed on eBay. You may also find it online at a used book-seller site. If your short is in the chassis electrical system, that system is the same in all F-250s, depending on accessories, etc and any wiring diagram for that should be adequate. I've found that Ford sometimes made running changes in electrical systems or wiring color schemes that weren't always shown in the wiring diagrams. Hope this is some help. Good luck finding your short circuit.
RussA
Old May 27, 2004 | 06:41 AM
bremen242's Avatar
bremen242
are you sure it isn't a Cali model with EEC-III?
Old May 28, 2004 | 04:11 AM
pilfit's Avatar
pilfit
I dont think so but how could I find out?
Old May 28, 2004 | 06:16 AM
bremen242's Avatar
bremen242
I think they have the computer under the drivers seat.. it should say up on the tag on the core support.. And I think they have a double headed rotor under the ignition cap.
Old May 28, 2004 | 10:07 PM
pilfit's Avatar
pilfit
my computer is under the dash and my rotor is the one that autozone says is for the TFI-IV. any one know what I should do about a eec coad 18? I have a ICM and the truck runs just not to well, lack of power bad mpg and its stalls when I stop. I dont think i'm geting any ignithion advance.
Old Jun 4, 2004 | 05:48 AM
pilfit's Avatar
pilfit
Ack I mean I have a new ICM
Old Jun 5, 2004 | 12:04 AM
howler's Avatar
howler
I can relate, my 83' F250 had a VV feedback carb, California emissions, etc... parts and manuals didn't jive, so a friend helped me convert it to a 75' duraspark II ignition... originally the truck had the box under the seat, and thousands of wires... now its down to 7 wires...
nofx guy
15
Aug 22, 2012 07:37 PM
Lance Hogan
Jan 3, 2011 08:58 PM
CALINLEIR
Apr 28, 2009 01:47 PM
Richharr
Engine Swaps
27
Apr 9, 2008 06:01 PM
Daves94vert
23
Oct 10, 2004 11:26 AM
