1982 EEC III loses spark
Old May 23, 2004 | 04:37 PM
KraigS's Avatar
KraigS
This is a 1982 F150 with a 351W EECIII.
I have a Haynes manual, but it only covers the EECII and EECIV, because it says "The EECIII was not used much and won't be covered in this manual..". SO, I need some tips on what to measure and what the measurements should be. What codes can be read and how to read them. The truck wont run long enough to bring it in to a shop.
Are any measurement the same as the EECII?
The module was replaced because the truck runs anywhere from a few seconds to several minutes and then quits. We take one of the plug wires, put it on extra spark plug and it has no spark. Wait about 30 seconds, then start it again, fine until it dies again. Same with the new module. Could it be the computer?
I have a remote ignition/starter box. I hooked this up figuring I'd be by passing the ignition switch and resistor wire. It worked, but the spark still disappears.
This truck had a variable venturi carb which flooded the truck constantly and a standard two barrel was put in its place.
Regards,
Kraig
Old May 24, 2004 | 11:09 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Check the resistance of the Crankshaft Position Sensor. When the CPS fails, it may work intermitently until you won't get any spark at all.
The CPS is clamped under the pulse ring behind the harmonic balancer. It's wires run up the front of the engine between the water pump and the alternator and then plug into the EEC wiring harness. There is an evap solenoid on the same conector. So for the CPS, test the Gray and Dark-Blue wires only.
The CPS should test 100-640 ohms. If it reads 'open circuit', it needs to be replaced. Test the CPS both before and after the engine quits. Wriggle the lead wires a bit to make sure that a frayed wire is not giving intermitent contact.
If you replace the CPS, gap it .075" between the tip of the lobes on the pulse ring.
(BTW, I am assuming that it ran okay after the standard 2 BBL carb was installed and now this is a new problem?)
Old May 29, 2004 | 09:25 AM
KraigS's Avatar
KraigS
I'm back at my folks. The resistance is 21.72 Meg ohms, then climbs up and then goes to "open". My Dad and I were talking, since we took the old variable venturi carb off a nd all those sensors do nothing now, we were thinking of switching to EECII. All we would need to do is replace the distributor and module, hook up vacuum advance to ported vacuum and time it, right?
Kraig
kickingber
26
Mar 11, 2016 09:14 PM
KraigS
Sep 30, 2008 11:31 AM
BobcatGuy
Feb 19, 2007 10:41 AM
movieprops
Jul 17, 2006 04:39 PM
