Sponsored by: Auxito
belt/pulley problem
Old May 23, 2004 | 03:12 PM
bigtom85's Avatar
bigtom85
Exclamation belt/pulley problem
i'm in the process right now of replacing my alternator. my problem is that the new alternator has 6 ridge pulley while the rest of the serpentine system is an 8 ridge pulley set up. should i try and switch pulleys on the alternators or use a narrower belt? i tried to get the pulley off the old alternator but with no success. any and all advice will be greatly appreciated.
Old May 23, 2004 | 08:17 PM
Camille Marquis's Avatar
Camille Marquis
try a big impact wrench or strap wrench and a quick blow to the ratchet with a hammer . without the 8 ribs the belt might slip and squeal alot.
Old May 25, 2004 | 08:34 AM
lariatrider's Avatar
lariatrider
First do you have acess to an air impact gun? If so the way I have removed many many many altenator pulleys is to clamp the altenator in a vise and grab your impact gun. Find the right size socket and you can zip the nut right off. Caution: some of these nuts are left hand thread so be careful to turn it the right way.
Old Jun 9, 2004 | 07:35 AM
The Grinch's Avatar
The Grinch
No vise is needed. Just a strap wrench and an impact wrench. I just replaced my alternator and pulley and these did the job. Takes no time at all!
Old Jun 9, 2004 | 06:15 PM
kevincook's Avatar
kevincook
Just keep fingers away from fins in case she starts turning.
