Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Searching for dry air
Old May 22, 2004 | 10:16 PM
Bikeitswift's Avatar
Bikeitswift
Well, I've been on a search for the best way to assure nice, dry air from my compressor, and some Forunm folks have helped, so here's what I came up with.
My compressor sits against the back wall of our three car garage. I have just been using a 25' 3/8 hose to run my air tools and Plasma Cutter, but, upon buying a new plasma cutter I deciided drier air was in order. I used 1/2 " galvanized metal pipe, put a "T" fitting out of the compressor's regulator/water filter and went up to the ceiling, and a 2 foot "drop" at the bottom, with a ball valve drain in it for moisture accumulation. Went across the ceiling with a 3 inch drop to a 20 foot coil of 3/8" id flexible copper tubing, which coils down (looks like a still) between two of the doors, to another "T", with another 2 foot drop to a ball valve, and at the "T" air exits up a 45 elbow up to another water filter then out. I can put a fan on the coils to further cool them when I'm working. possibly with a "mister".
I don't know how to post any pictures.
Old May 23, 2004 | 06:50 PM
mantta's Avatar
mantta
Your best bet is to use a refrigeated air dehydrator. We use them to condense the moisture out of air that is used in control air for pneumatic HVAC controls. They are expensive though.
Old May 23, 2004 | 07:12 PM
Sberry27's Avatar
Sberry27
Yup, a de- hi is good. A cheaper way is to build a condenser that goes between the comp pump and the tank. A couple guys, Echo for one has copied old fart Franz's design over on www.weldingweb.com I think echo has posted design pics.
