DRL modules
I have also posted a "wanted" ad in the classifieds.
Thank you for any help any of you can provide.
dn.
. The second type plugs in under the dash inside the cab. Confused yet I hope not. Here's how I solved my DRL dilemna about a year ago. I searched the web for DRL. There was a site on there where a guy showed pictures of what the 2 types of modules looked like. No one was able to provide an exact location on the vehicle but I atleast knew what they looked and then I went searching the wreck yards. I know for sure the olders styles are a small black 3 " box with cooling fins. On Tempo's they are hiden on the rad suport beside the rad about half way down on engine side. On my 94 F150 it was on the driver side rad support in by the bumper. (easier to feel than to actually see). On newer f150's 97 and up they are under the dash cover on the passenger side. (newer style)Once you get one they plug in easily. Remember if older style to install in a well ventilated area as they are proned to overheating and early failure. Overall a good safety idea but you can tell that it was a Ford afterthought.
Hope this helps and good luck
Truckfarmer
PS For you Ford wanted 121$ CDN plus tax for a new one
Thank you for the response. I have purchased new DRLs through Ford Parts here in the US, but was hoping to find used ones where they are more prevalent-there in Canada. DRL is/was only optional down here, but most models have the wiring in place for it. I do know that I need the "earlier" style for our 91-96 Broncos, F-Series, & Explorers.
Is this an item commonly available through salvage yards? And do you folks have "you-pull-it" type yards up there? Also, if so, what price range? I have bought them through Ford for about $60 US so was hoping to do a lot better than that.
However, if they are prone to early failure maybe used is just buying someone else's headaches. Or the demand domestically is high enough to drive up price & keep availability down.
Any other thoughts?
Thanx,
dn.
Yes we do have pull it type yards. I'm not sure what they would charge. As mentioned the hardest part is finding them on the car itself. If interested I have an extra one that I will sell you. Send me an e-mail and we can discuss further. (System won't let me e-mail you due to my low # of posts)
later
Truckfarmer
TJstruckfarm@sympatico.ca
