another newbie towing question
Old May 22, 2004 | 06:54 AM
titansfan's Avatar
titansfan
I have a 98 f-150 4.6l with auto transmision and 3.08 gears, factory towing package,equalizer hitch, and 67000 miles. I just bought a 26 ft keystone springdale pull behind tt that wieghs 4620 lbs dry.Three people of average wieght. I know the truck is rated at 5500 lbs. I dont put a lot of gear and such in the tt for camping. just wanted to know if the salesman sold me more tt than I should have bought. can anyone help with this. Thank you.
Old May 22, 2004 | 07:51 AM
04superduty's Avatar
04superduty
That is going to be alot of weight to tow with your truck, especially with the rear axle ratio you have.
Old May 22, 2004 | 10:32 AM
johnsdiesel's Avatar
johnsdiesel
I agree with 04superduty, that is a lot of weight considering your 3.08 gear ratio. If you plan on keeping the truck for a while you should consider swapping gears. If not, now is the time to trade.
Old May 22, 2004 | 12:48 PM
titansfan's Avatar
titansfan
how bout the 2004 f-150 do you think that would work?
Old May 22, 2004 | 02:16 PM
Auburn1's Avatar
Auburn1
The 2004 F150 is beefed up compared to the previous generation. In fact, with the same gears and engine, the F150 has a higher tow capacity than the F250, which I believe is attributed to less chassis weight being attached to the same frame. Personally, I think your truck will tow that load fine unless you need highway speeds or go on long distances...the concern is long term wear on bearings, etc, and of course stopping. Any 8 cylinder version of the 2004 models will be more than adequate if a new truck is an option.
Old May 22, 2004 | 02:22 PM
johnsdiesel
Yes, that would be a good idea. I would recommend the 5.4 instead of the 4.6.
Old May 22, 2004 | 07:40 PM
SoCalDesertRider's Avatar
SoCalDesertRider
What John said...and the optional low gear ratio.
Old May 22, 2004 | 08:00 PM
04superduty
Remember with a camper you may think the extra stuff you put in doesnt adds much weight but you would be suprised. Add water, food, clothes, popane, and it could easly be an extra 1000 lbs. Go to a scale before your trip and find out how much it really weights and then go for a drive to see how it tows. You may have to move things around to get the weight distribution right. hope that helps. And yes the new f 150 will handle it, but a 250 isnt much more and in the future you might need the extra capacity.
Old May 23, 2004 | 07:15 AM
titansfan's Avatar
titansfan
Doulble Thanks Guys . Can't afford the F250 but have already looked at the F150. I believe its time for a trade. Thanks for all the post. I really enjoy this site.
